Network Management
Trusted Contributor I
Instant automatic configuration with Airwave
i have my DHCP scope setup with option 43 and 60. the new APs find the AirWave server and receive their golden config.
but when i then access the IAP via the GUI im asked to configure a country code, which fails as the AP is management by AirWave. is this normal behaviour? i would expect the IAP to already receive this from the AirWave.
Moderator
Re: Instant automatic configuration with Airwave
What version of AirWave and Instant firmware?  If you can provide the details, we can have a team member replay the same combination in the lab.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
thanks Rob
Airwave: 8.0.7.1
Instant: 6.3.1.4-4.0.0.6_44126
if you believe a later version will work differently i can try that also.
if use template, please check if template missing a line such as:
version 6.4.2.0-4.1.1
virtual-controller-country CA
if you need to know the code, please let me know the country you wanna select.
if use IGC, please enbale [allow configuration of airwave settings] in Airwave->Airwave Setting,
then select country under System->General page.
ah Airwave Config setting, missed those. thanks wdeng.
should i enable [Allow Configuration Of Airwave Settings]? shouldn't i enable [Allow Configuration Of Country Code] ? because with the first option i would assume it also overwrites the org string which i don't want to.
my mistake, should enable [Allow Configuration Of Country Code]
not a problem, that did indeed the trick, thank you.
