Network Management
Occasional Contributor I
Integrate airwave reports with a dashboard embededd code
In the company that i work they have airwave,
I want to integrate the reports with an embededd dashboard software
is it possible?
does anyone have done this?
thanks
Valued Contributor I
Re: Integrate airwave reports with a dashboard embededd code
When you say "embededd dashboard software", what exactly do you mean?
Kudos appreciated, but I'm not hunting! (ACMX 104)
Sounds like you might want a public facing report page that can be embedded into a web site or internal application?
Tim Cappalli | Aruba Security
Yes thats my objective.
I'm using Xibo to do the dashboard but so far I cannot put the airwave reports embedded in xibo.
Can anyone help with this :)
thanks
There is an active feature request for a public facing dashboard. It is on
Aruba's radar.
cappalli thanks for the answer
Can you please help me find the aruba radar?
I search for it but couldn't find anything
thanks
Sorry, just a figure of speech. I meant to say Aruba is aware that this is a feature that customers want and is evaluating how to implement it.
