Network Management
Integrating Airwave with Active DIrectory through Freeradius
Hello community, basically what I am trying to do is authenticate wireless users in my network using active directory credentials. To achieve that, i am trying to conect an installed Airwave to Active Directory using Freeradius as the radius service.
I know there may be better solutions with other software, but I beg you to give me a hand if you can giving me some hindsights of how to conect these three together
Thank you in advance
Re: Integrating Airwave with Active DIrectory through Freeradius
Integrating AD with Freeradius is one thing.
Integrating Airwave with Freeradius is another thing.  How do you want to integrate Airwave with Freeradius?
The end goal of this is for Airwave to use AD credentials to authenticate wireless users
#AirheadsMobile
To Authenticate Wireless management users?  Airwave cannot authenticate wireless users.
Sorry, I meant to say that I want Airwave to connect to a radius server (in this case freeradius). Then I want freeradius to use active directory credentials to authenticate uses Since I am a bit new to this subject, maybe my ideas in the subject are still a little fuzzy
#AirheadsMobile
#AirheadsMobile
Airwave is a network monitoring / management solution. You cannot authenticate network users against Airwave. For wireless user authentication against AD, probably you must use Clearpass.
