Network Management
Is there way to generate a report showing what switchport an ap is on in AirWave?
Is there way to generate a report showing what switchport an ap is on in AirWave? I know I can do this on a per AP basis but is there a way to gerneate a report so I dont have to drill down into 300+ items to see it?
Re: Is there way to generate a report showing what switchport an ap is on in AirWave?
I don't know about Airwave, but from an Aruba or HPE switch try:
#show lldp info remote-device
The output will look something like this.
 LLDP Remote Devices Information
  LocalPort | ChassisId          PortId             PortDescr SysName
  10        | a01d48-abc123      1                  Port #1   SW2
  11        | c8b5ad-abc124      c8 b5 ad c4 ef 80  bond0     AP1
  12        | c8b5ad-abc125      c8 b5 ad c4 ef 92  bond0     AP2
  13        | c8b5ad-abc126      c8 b5 ad c5 3a 32  bond0     AP3
  14        | c8b5ad-abc127      c8 b5 ad c4 eb 70  bond0     AP4
  15        | c8b5ad-abc128      c8 b5 ad c4 ef 78  bond0     AP5
  24        | 441ea1-abc129      1                  A1        SW1
Moderator
Try the Port Usage report -> incluse details about each port (specifically 'Device') - this should populate with the downstream device entry that maps to that port.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
