Network Management
Contributor I
List ssid and vlan per AP
Airheads -- is there a way to query Airwave's API to list each AP's ssid and associated vlan?
thanks
Mike
Moderator
Re: List ssid and vlan per AP
Not currently, this would be a feature request.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor I
Thank you.
Actually, SSIDs are available in the ap_list.xml API.
Contributor I
Thanks for the reply - yep, I did know about that, but I'm looking for the ssid-to-vlan mapping.
Mike
