Network Management
Frequent Contributor I
Listing 2.4 or 5GHz on instant
We have about a dozen APs 225s that are on one network.  We have a lot of connectivity issues and I'd like to know which clients are on 2.4ghz vs 5ghz.  Is there any easy way to see them on the web interface?   We also have airwave if that is better to get that info.
Aruba
Re: Listing 2.4 or 5GHz on instant
For proper/faster responses, please post to the Instant forum in the future for IAP related questions:http://community.arubanetworks.com/t5/Aruba-Instant-Cloud-Wi-Fi/bd-p/IAP]
Through IAP, client the Client hyperlink on the top right to view expanded info.  The Type column shows the band.
Through AirWave:
Add the "Connection Mode" column to the Clients view to see the radio the clients are on:
AMFX | ACCX | ACDX | ACMX
[ Sorry, responded to the wrong thread :) ]
Tim Cappalli | Aruba Security
Thanks.  I see GN, AN AC... is AC always 5GHz?
Aruba
Yes, A, AN, and AC are 5 GHz.
B, G, GN are 2.4 GHz.
Thanks!
