Network Management
Looking for SNMP OIDs for packetrate monitoring
Hi everybody,
since a few weeks we're running a grafana/graphite setup to have another solution to monitor our wifi better. We get nearly all the data wee need, but I want to get the data, from which the frame rate/type graphs on the controllers dashpage are generated. I found the ArubaOS 6.0 MIB Guide, but I can't find the right OIDs. Are they named in a different way or am I overlooking something?
ArubaOS: 6.5.0.1
Controller: 7220
kind regards,
Hendrik
Re: Looking for SNMP OIDs for packetrate monitoring
Search with keyword frame/rates in MIB guide, you could find list of OIDs which are realted to frames/stats.
Pavan
If my post address your queries, give kudos and accept as solution!
