Network Management
Occasional Contributor I
#MHC Predictive Survey using Airwave
How to use Airwave to perform a predictive survey.
Yes some people disagree with predictive surveys due to algorithms and methods. I believe they are incredibly good for saving time. You will already know when you get onsite the location of the AP and you can take right off with the active survey.
