Network Management
MSM-management in airwave 8.2
I'm adding a HP MSM environment (MSM-teamed) into an Airwave 8.2 server.
The controllers are visible in Airwave, but team status , AP's or clients are not shown.
The controllers are discovered also webmanagement is possible from Airwave.
Does anybody know if it's possible to show the AP's or clients ?
Re: MSM-management in airwave 8.2
i attached config page of msm (group in amp) snmp v2 is used.
msm config is not changed, discovery used same snmpv2 community
