Network Management
MTBF for AirWave
What is the MTBF value for the AirWave? Spec and data sheet don't include this information. Neither do the AP-274.
Re: MTBF for AirWave
Airwave is software, so doesn't have MTBF values. For the Airwave hardware appliance, check here.
And for the AP, check MTBF for AP-270 platform.
Thanks Herman,
Is this listed in any aruba ocumentation that is available to public? I need to reference it for internal company documentation.
The document that describes these numbers is not public, some of these numbers show up in the datasheets though. For products that don't have MTBF numbers in the datasheet, your Aruba partner or Aruba SE can probably provide them, or confirm the numbers posted on Airheads community.
