Network Management
Occasional Contributor I
Manage hp procurve switsj using airwave?
Hello everyone.
I'm quite new to airwave, but I've been told that it's possible to import and manage our HP procurve switches using airwave.
Importing them into airwave is really straightforward, and monitoring works. But I'm not able to push config to them or any.
Could someone confim that this is actually possible?
And if so provide some details on how to make it work?
Odd Gaute
Re: Manage hp procurve switsj using airwave?
Please look at the Airwave Supported Infrastructure Guide here:  http://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14102
It will tell you  what can be done with HP switches and Airwave.
Looks like it 's not meant to do the job I was hoping for..
I guess I'll just have to find another tool for that job then.
Thanks for the link.   :-)
Have a nice weekend.
