Network Management
Contributor II
Mapping of air health with AirWave
Does anyone know if it would be possible to generate a report in AirWave depicting all of the current interference and foreign SSIDs with the relevant power level for each AP?
Ultimately, I would like to see it as a heat map overlaid over the VisualRF but I am not sure that would be possible.
Moderator
Re: Mapping of air health with AirWave
You're probably going to want to focus on 2 different reports.
1) RF Health report for interferers
2) Rogue report for APs classified as rogues
2b) if the Rogue report doesn't provide the details you're looking for, you can always filter/sort the RAPIDS List view, and then export as CSV.
The last part about a VisualRF view would be a great idea to submit into the ideas portal on the support site.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
