Network Management
Mismatched configuration in AirWave after configuration
Hi guys,
I have a Instant cluster made up of 16 IAPs. I have configured one of them, and the only change I made it to set the Installation Type from Default to Outdoor, and reboot this AP, nothing else.
After making this change, AirWave shows the message Mismatched, as showed below:1.PNG
When I go to Instant Config I see the following:
b4:5d:50:c9:88:80 is the MAC address of the AP I made the change to. I don't understand the message "Config changes waiting to be applied" since when I made the change, I clicked apply and then rebooted the AP.
Within Instang Config > Access Points I see the following:
And when I select the AP I see parameters which I didn't change and they are set to default, as the name (the AP has a name and now shows the MAC address, and it had a static IP and now it shows by DHCP) and the uplink VLAN (it was 800 and now it shows the default VLAN 0):
And Installation Type keeps appearing as Default:
So what is happening? How can I have this configuration done correctly and get rid of the Mismatched message?
Please help.
Julián
Re: Mismatched configuration in AirWave after configuration
Hi Julian,
May i know the Airwave version and IAP model/firmware version. After changing the installation type, just VLAN and name been changed to default or complete configuraoitn been set to default?
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Hi Pavan,
No, this is only as seen in AirWave, because I have seen the AP and it has the configuration of the cluster and the IP and uplink VLAN it used to, otherwise I would have losen connectivity with it. I think AirWave is waiting I click apply to set these parameters to default, so I didn't click, otherwise I will loose connectivity with this AP and I will have to go and connect by console to change uplink VLAN and IP address at least.
I don't know why AirWave makes it hard, it is version 8.2.3.4 and the cluster is running 6.5.1.0-4.3.1.3, which is supported by this AirWave.
I think I will have to set AirWave to read-only mode, make the configuration by the Instant GUI and set AirWave back to read/write mode.
Julian
We dont have 8.2.3.4 version, I believe server is in 8.2.3.1.Tested in my lab and it is working fine. Went to VC page and clicked on VC and went to Installation Type and choose indoor and clicked apply. Configuraiton pushed succefully and device rebooted automatically and came up after few minutes.
Config is getting pushed without any issues
2017-06-30 05:04:20,627 INFO  Config       36 cluster [instant-C8:20:A0] has been updated, disabling auto-repair
2017-06-30 05:04:08,723 INFO  Config       36
User: admin sending delta:
  "ap_id": "36",
  "command": "config_update",
  "delta_config": "\nper-ap-settings 18:64:72:c8:20:a0\n ap-installation indoor\nexit\n",
  "username": "admin",
  "hashed_management_password": "0"
Running config of IAP after config get pushed.
 hostname 18:64:72:c8:20:a0
 ip-address 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 ""
 swarm-mode cluster
 wifi0-mode access
 wifi1-mode access
 a-channel 40 20
 g-channel 6 30
 uplink-vlan 0
 a-external-antenna 0
 g-external-antenna 0
I believe you might have done something wrong.
Pavan
If my post addresses your query give kudos:)
Pavan
Hi Pavan,
Sorry, it is AirWave 8.2.3.1 as you say. Today I have tried again and worked properly. Because the device doesn't reboot inmediately and takes a momment, the problem I had was I rebooted the AP manually after making the change and then AirWave didn't have time to push it the config. So it was my fault.
Apart from that, finally I set the power statically in order to have the max power. Before making the change, ARM set the channels to 1 and 149E, I wanted to set the same channels but for the 5 GHz band I can't set 149E, only 149, do you know the meaning of the letter "E" or the difference between 149 and 149E?
Julián
Check this link which explain the difference https://community.arubanetworks.com/t5/Wireless-Access/IAP-225-wifi-channels/td-p/194265
Pavan
Pavan
Hi Pavan,
Thank you. And is there a way to allow 40/80 MHz channels from AirWave when the channels are statically selected? I can't find the option.
Julián
Because I only see the option in the ARM section
Julián
