Network Management
Contributor II
Missing AirWave Key
i have taken over the AirWave management from another employee and im trying to add another group to AirWave.
When i get to the Admin page of the new Group its asking for an AirWave Key.
The employee doesnt remember the key so im trying to figure out how i can find the key. By the way, there are two other groups created with the key in them but i cannot see the text of the key.
Re: Missing AirWave Key
Screen shot which you have shared with Airwave details, will show in IAP's  system>Admin page.
Do you want to add new IAP to Aiwave or create a new group in Airwave, if you want to create a new group , login to Airwave and go to Groups tab and click create new group.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Contributor II
the group is created but when i go to Edit for the new group and then to Instant Config then click on the System tab in the left hane column and then click the Admin tab it ask for a AirWave Key. The other groups that are created have text in the key fields.
Contributor II
i have fixed the issue. I had to create the group in activate.arubanetworks.com site which them added it to the aruba management site.
