I'm trying to find a way, when viewing the APs in ">> Monitoring >> All Access Points" to change the default from 10 to 25 or even 50 per page.
I know there is the dropdown box that allows you to change it to 5, 10, 25. 50, 100, 1000 but that is a temporary change as next refresh it goes back to 10. If I can't change the default number can I change the refresh rate as <1m is driving my eyes crazy? :)
Thanks in advance.
