Network Management
Contributor II
Monitor Only mode question
Network setup looks like:
- IAP clusters in several Groups
- AirWave appliance
- ClearPass appliance
Due to Aruba's default Captive Portal certificate revocation we need to replace it with new public certificate (wildcard, btw) using AirWave on several locations. Those clusters are in "Monitor Only" mode at the moment, so my question is can we get the certificate uploaded to them without moving them to a "Management" mode (I am aware that firmware upgrade can happen in Monitor mode)? Thanks in advance.
AlanFord
Kind regards,
AlanFord
Re: Monitor Only mode question
In a word no.
However you can apply changes whilst in monitor mode If you have a maintenance window scheduled in Airwave for your devices, Airwave will push the configuration it has onto your devices regardless of them being in monitor-only mode.
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Contributor II
Thanks, appreciated!
AlanFord
Kind regards,
AlanFord
