Network Management
Monitoring CPPM and Controller licenses using SNMP
Hi all,
i am trying to monitor our CPPM and Aruba Controller using SNMP either via Powershell or PRTG. Do you know if there is any known OID that indicates the license usage or any other way to monitor the licenses?
Thanks in advance for your help
Jannis
Moderator
Re: Monitoring CPPM and Controller licenses using SNMP
You can walk the controller for the 'licenseKey' OID (.1.3.6.1.4.1.14823.2.2.1.1.1.8.1.2)
I ran the cmd through AirWave's AMPCLI -> Enter Commands menu
(link to AMP-TIP that walks through the SNMP portion of enter cmds)
$ sw2 13 licenseKey
WLSX-SWITCH-MIB::licenseKey.1 = STRING: AAAAAAAA-AAAAAAAA-AAAAAAAA-AAAAAAAA-AAAAAAAA-AAA
WLSX-SWITCH-MIB::licenseKey.2 = STRING: BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB-BBBBBBBB-BBB
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Moderator
Checked with ClearPass team, they don't expose the license keys through SNMP.  It'd be a feature request to have a ClearPass OID for license keys.
Rob Gin
Hi all,
thanks for your answers. There might some misunderstanding. I am not trying to retrieve the license key. Rather i would like to see the following data from cppm > administration > server manager > licensing:
Policy Manager: Total Count and Used Count
Guest: Total Count and Used Count
Clearpass Enterprise: Total Count and Used Count
In advance to starting this, i knew it was going to be a hard task to realize but unfortunately i turned out to be even more difficult.
I really appreciate your help...
Jannis
