Network Management
Monitoring SNMP enabled IoT devices
Hi All
With IoT on the increase thought I'd share a way to mange those SNMP enabled devices such as aircondioners, UPS, door security systems, AV systems and others.  Using the IMC MIB import function 3rd party device mibs can be loaded into the platform.  Custom monitors can then be defined and applied to the device(s) providing visbiility into the status of the device(s)
The link below provides a walkthrough of adding custom SNMP polls to track power usage on Server Technologies Intelligent Power Distribution Unit as an exmpale.
If you'd like to try this out, a 60 day eval version of IMC can downloaded @
