Network Management
Contributor I
Monitoring hack for ap usage without airwave
Hello everyone,
We don't run Airwave here before anyone recommends it :)
I was hoping to see if anyone uses any open-source tools to monitor amount of users per ap and any other stats you might find interesting to know whether it's a daily update or a real-time graph using SNMP?
We already use the great nagios hack to monitor for up/down - hoping to find some other useful approaches people have had!
Re: Monitoring hack for ap usage without airwave
There's not many out there that I'm aware of, the tricky part is being able to parse the user table properly.  The user table contains the correlation between user and AP.  Also, it depends on the scale of your deployment and how often you plan to request/get updates as SNMP has limitations causing a push for moving to AMON (Aruba proprietary data stream) sooner which is currently work in progress.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
