Network Management
Occasional Contributor I
Monthly Maintenance - Airwave
Hi All,
I would like to check if we have a procedure for monthly maintenance?
Our Server Team would like to reboot our airwave server every month during our maintenance window.
Any service/process in airwave should we follow before we can reboot the actual server?
Aruba
Re: Monthly Maintenance - Airwave
There is no need to do that, but certainly use that time as an opportunity to do any upgrades.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
Thanks for the quick reply.
So I will just tell them to reboot the server and all sevices/db should be back up after the reboot?
Aruba
if it must be done, the I would do like this.
amp_disable
reboot
