Network Management
Frequent Contributor I
Most clients/devices not showing up in Visual RF
We have about 135 connected users currently using the APs on our network.   It shows 135 connected devices under clients.   Likewise if I connect to the AP cluster directly on the home page it shows the same number.   When I click on Visual RF it shows my 10 APs.but it only shows about 6 connected clients.
I'm running 8.0.9.1 and have 16GB of memory dedicated to the VM which has a disk size of 127GB.
I'm new to Alcatel wireless and I've never tried OV before.
Re: Most clients/devices not showing up in Visual RF
On the VisualRF page, instead of Maps, click on List to see if it details how many APs and clients are on that floor...
Thanks - same issue on the list page in Visual RF.  It shows my APs but all the connected clients.
Just to be clear, does it show 135 devices in the list view or not?
It is early morning so currently there are only 35 clients connected.    It shows that at the top of the screen
UP -12 devices, Down 0, mismatched 0 ... Clients 35
If you select visual RF
Go to list view instead of map
It shows the APs in the APs column but in the clients column  it isn't currently showing ANY clients even though above on that same page it shows clients 35.
The issue is resolved.  Changing the virtual controller ID seems to have resolved the problem
MVP
Would you please elaborate?  Where did you make that change?
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
In the CLI of the AP you can change the virtual controller key but since I don't know it that well, you can go to maintenance in the GUI, then make a backup, modify the file in wordpad and then restore it.
Contributor II
Boe, I would like to know more about this "Virtual Controller ID", what is that and what does it do? I have had issues before with clients not showing up and turned out to be that the controllers "enable" password wasn't correct so the Airwave could not gather up all of the information about the clients. Some sites I still have issues with, even though I have the correct Enable password.
I'm a complete newbie so you'd probably best get someone else to answer but I'll give you what I got.   I think the airwave communicates with the AP cluster and the virutal controller ID is how it knows which cluster is which when gathering info.  I think it might be possible for it to cache an incorrect ID so they don't reliably transfer info/statistics.   I think it regathered the key information for good communication when changing the virtual controller id - about the 3rd line down in the identity file it downloads when you make a backup.
