Network Management
Contributor I
Move Suspected Rogue to Rouge AP
Dear allfriends and expert,
Im researching WIPS/WIDS features with RFprotect license.
When i plug into an AP ( Aruba) to network and broadcast random SSID.
My controller dectect it AP is Suspected Rouge.
my understand IPS/IDS does not apply for Suspected rouge AP right ?
Thank you so much !
Re: Move Suspected Rogue to Rouge AP
It is dependant on your WIPS rules and what is configured in regards to . If the controller sees evidence of the Suspected Rogue AP on the wired side, it will classify it as Rogue and your containment rules (if any) will be actioned. You can also configure rules to contain suspected rogues based on their calculated confidence level.
Protect Suspect Rogue
If you need to manually contain an AP, you can do so via Manual Containment under Security -> Contain Manually
Take a look at this as it contains some really good information.
http://www.arubanetworks.com/assets/tg/TG_WIP.pdf
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/New_WIP/Rogue_AP_Detection.htm
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Thank you so much !
You can just enable "Suspected Rogue Containment" in the IDS Unauthorized Device Profile:
