Network Management
Multi floor planning with VisualRF 8.0 rc1 build 496
I want to use the "Origin" point on multiple floors so that the planning tool doesn't stack access points on top of each other.
I don't seem to be able to access the origin point until after the access points have been placed on the floor. I can then move the origin point where I want, but can't find how to re-deploy the access points after that.
Can anyone tell me how to redeploy the access points after placing the origin point(s) on the floor plan?
