Network Management
NPS Configuration for Airwave Management Access
Hello all...  The only point I am lost on is the Vendor Specific Attributes.  Neither Aruba or HP are in the dropdown list, so I don't know what to choose, and I don't know the syntax for the Attributes to configure.  Any assistance offered would be greatly appreciated.
Re: NPS Configuration for Airwave Management Access
Please check to learn how you can add the Vendor Specific Attributes to NPS.
There is a table of the ID numbers that you need for each attribute as well; you only need to add the attributes that you will actually use.
You need to return the Aruba-Admin-Role.  In the example below I am returning read-only.
That is using PAP also.  I am seeing issues with PEAP-MSCHAPv2.  Hope that helps.
ACCP, ACCX #817, ACMP, ACMX #294
