Network Management
LDB
Named a controller (device) in Airwave a name already used. How do I change it?
Not sure what group to send this to.  I accidentally created a device (a 3400 controller) in Device Setup using a device name that already existed.  Acronyms can look so much alike.  I added it to a group with the correct IP #.  How do I change the name or delete it so I can recreate the correct name.  It has caused a problem with the original device with conflicting name.
Re: Named a controller (device) in Airwave a name already used. How do I change it?
The Manage tab when a device is open will allow you to change the name.  Make sure you change the hostname on the controller, as well.  If you already changed the name on the controller, You can click on Import Settings in Airwave to pull in the new name of that device.
