Network Management
Occasional Contributor I
Need info of Airwave "unknowns"; is this a problem?
This is a copy/paste of a customer's device type summary report and I want to know how I decipher these "unknowns"? I've read mixed threads that these could be devices from neighboring wireless networks and/or devices that have cannot or have not attempted a CP redirect. Ideas?
MVP
Re: Need info of Airwave "unknowns"; is this a problem?
If you navigate to the Clients page in Airwave, you'll see a set of donut graphs - you can click on the device types in the list to get a search list of the currently connected so-categorized clients:
A small bit of mine look like this:
That should give you something to track down and start to get insight into those unknowns.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Unknow devices are nothing but Aruba OS not able to classify those list of client device type based on their OUI.
If OUI enteries not present database , it places devices in unknow list.
Based on AMP Setup > Device type setup setting, airwave will classify type.
Pavan
If my post addresses your query give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
