Network Management
Network Usage reports
Hi, I have a few questions about the Network Usage report and how to format it.
I am looking to only show the top 10 folders by maximum number of clients, is this possible?
Is it possible to overlay the lines for number of clients on to the one graph?
I can export a CSV of the data, but this does not have a field that shows what folder the data is from - how would I add this? (apart from manually!)
Thanks in advance!
