When I log into Airwaves (8.2.1.1), I recieve the following message:
Nightly maintenance failed because of unsuccessful jobs: clean_database. Contact Aruba Technical Support at support@arubanetworks.com or 1-800-943-4526 (800-WiFi-LAN).
I checked to make sure that the nightly maintenance is not running by doing the following:
#psg night
#psg maint
#psg backup
Nothing was running.
I checked the log files that are located:
/var/log/nightly_maintenance
/var/log/nightly_backup
I did not see any errors.
I checked the timestamp on the backups and they align with when Nightly Maintenance is set.
Nightly Maintenance Time is set at 04:15
The time stamps on the backups are 04:40, 04:41, 04:39, and 04:41.
Are there any other places I can look to try and find what is causing this error?
Thank you
