Network Management
Contributor I
No GUI after 8.0.4 upgrade
After AMP update to 8.0.4 (VM) the GUI seems to be dead?
I'm able to ssh to the VM and manage from CLI, but no gui.
Any help?
/niklas
Super Contributor II
Re: No GUI after 8.0.4 upgrade
Have you tried clearing your browser cache or using another browser?
Frequent Contributor II
Hi
I have done two upgrades to 8.0.4, one in my lab and one to a customer.
Both works like a charm, i think clearing the browser cache, as MattF suggests, will help you.
Roar Fossen
Contributor I
No sadly. I have tried in 3 browsers and none of them works.
any other suggestion?
/niklas
Oki, if you haven't tried a reboot, do that.
Otherwise try the amp_disable to stop det AMP application and do a amp_enable after that.
This is done in the CLI after you connect to the AirWave with SSH.
Roar Fossen
Contributor I
I've done that, and it did not help.
is there anything else?
/niklas
Aruba
if you issue the command "daemons", are all services running?  Have you tried rebooting the VM?
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Moderator
Please open a support case.  Things to include:
/var/log/upgrade/AMP-upgrade-version-history.log
/var/log/upgrade/AMP-8.0.4-upgrade.log
Things to check:
# daemons
(are there 12-15 daemons running?)
# service httpd status
(is apache running?)
# service pound status
(is the login web server running?)
# root; svn info
# amp_version
(does URL from svn info match the version in amp_version? amp_version is a database field)
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Contributor I
[ Edited ]
[root@wireless mercury]# daemons
PID PPID PGID %CPU %MEM RSS ELAPSED CMD
4150 1 4150 0.0 17.4 1045180 03:18:11 Daemon::AMONAggregator
4182 1 4182 0.3 17.4 1043140 03:18:09 Daemon::APListCacher
4186 1 4186 0.0 17.4 1043448 03:18:09 Daemon::APScanner
4190 1 4190 0.0 17.4 1042740 03:18:09 Daemon::APWatcher
4193 1 4193 0.0 17.4 1042984 03:18:08 Daemon::APWatcherPollNow
4176 1 4176 0.0 17.4 1042744 03:18:09 Daemon::AlertD
4333 1 4333 0.0 17.4 1045256 03:17:56 Daemon::AsyncLoggerClient
4197 1 4197 0.0 17.4 1043544 03:18:08 Daemon::AsyncLoggerClient
4200 1 4200 0.0 17.4 1042688 03:18:08 Daemon::ConfigPusher
4207 1 4207 0.0 17.4 1042696 03:18:07 Daemon::ConfigVerifier
4210 1 4210 0.0 17.5 1046908 03:18:07 Daemon::ConfigWrangler
4220 1 4220 0.0 17.4 1042988 03:18:06 Daemon::DNSFetcher
4213 1 4213 0.0 17.4 1044972 03:18:07 Daemon::DeviceEvent
4217 1 4217 0.0 17.4 1043404 03:18:07 Daemon::DeviceHTTPSHandler
4147 1 4147 0.0 17.4 1044736 03:18:11 Daemon::ExecUIQuery
4024 1 4024 0.2 0.5 27824 03:18:19 Daemon::LowLevelServiceWatcher
4226 1 4226 0.0 17.5 1047916 03:18:06 Daemon::PAPI
4229 1 4229 0.0 17.4 1044428 03:18:06 Daemon::PAPIDecoder
4339 1 4339 0.0 17.4 1045948 03:17:55 Daemon::PAPIDecoder
4232 1 4232 0.0 17.4 1044468 03:18:05 Daemon::PAPIQueueConsumer
4236 1 4236 0.0 17.4 1044792 03:18:05 Daemon::PEFProcessor
4223 1 4223 0.0 17.4 1042964 03:18:06 Daemon::PartialConfigPusher
4172 1 4172 0.4 17.4 1044368 03:18:10 Daemon::PerfCollector
4125 1 4125 0.0 17.4 1043040 03:18:12 Daemon::PortGrabber
4242 1 4242 0.0 17.4 1042700 03:18:05 Daemon::SNMPEnabler
4245 1 4245 0.0 17.4 1043156 03:18:04 Daemon::SNMPFetcher
4251 1 4251 0.0 17.4 1043856 03:18:01 Daemon::SNMPV2Fetcher
4254 1 4254 0.0 17.4 1043856 03:18:01 Daemon::SNMPV2Fetcher
4239 1 4239 0.0 17.4 1043576 03:18:05 Daemon::Scriptorium
4039 1 4039 1.4 17.4 1045292 03:18:14 Daemon::ServiceWatcher
4152 1 4152 0.0 17.4 1043864 03:18:10 Daemon::SwarmHandler
4257 1 4257 0.3 17.5 1046208 03:18:01 Daemon::SyncD
4267 1 4267 0.0 0.5 31908 03:18:00 Daemon::TranslationServer
4131 1 4131 0.0 17.4 1043104 03:18:11 Daemon::TupleScheduler
4128 1 4128 0.0 17.4 1042988 03:18:11 Daemon::TupleSpaces
4315 1 4315 0.0 17.6 1053292 03:17:59 Daemon::UCCProcessor
4302 1 4302 0.0 17.4 1043304 03:17:59 Daemon::WepKeySetter
4298 4296 4296 0.6 2.6 154220 03:17:59 IGC
4087 1 4086 0.3 0.7 39412 03:18:12 RabbitMQ
12329 12328 12328 58.3 1.7 99916 00:11 VisualRF
4043 1 4043 0.0 0.3 20056 03:18:12 airbus
3988 1 3988 0.8 17.5 1049472 03:19:50 httpd_
4161 1 4039 0.0 0.0 504 03:18:10 msgHandler
4142 1 4142 0.1 0.2 9492 03:18:11 redis
1546 1 1546 0.0 0.0 1756 03:31:02 rrdcached
4249 1 4249 0.0 1.7 100500 03:18:01 snmptrapd
[root@wireless mercury]# service httpd status
httpd______________________________________ (pid 4339 4333 4315 4302 4257 4254 4251 4245 4242 4239 4236 4232 4229 4226 4223 4220 4217 4213 4210 4207 4200 4197 4193 4190 4186 4182 4176 4172 4152 4150 4147 4131 4128 4125 4039 4038 4037 4036 4035 4033 4032 3988) is running...
[root@wireless mercury]# service pound status
pound is stopped
[root@wireless mercury]# service pound start
Starting Pound: starting...
/etc/pound.cfg line 14: SSL_CTX_use_PrivateKey_file failed - aborted
[FAILED]
[root@wireless mercury]# root; svn info
Path: .
Working Copy Root Path: /root/svn/mercury
URL: http://svn.corp.airwave.com/usr/local/svnroot/mercury/tags/RELEASE_8_0_4
Repository Root: http://svn.corp.airwave.com/usr/local/svnroot/mercury
Repository UUID: 99f6a4a8-5413-0410-a0fb-e6b940866760
Revision: 84390
Node Kind: directory
Schedule: normal
Last Changed Author: aaron
Last Changed Rev: 84390
Last Changed Date: 2014-09-09 15:08:56 +0200 (Tue, 09 Sep 2014)
[root@wireless mercury]# amp_version
8.0.4
[root@wireless mercury]# cat /var/log/upgrade/AMP-upgrade-version-history.log
Thu Jun 12 09:08:37 GMT+1 2014 From: 7.7.9 To: 7.7.11 - Upgrade successful.
Thu Jul 31 13:40:54 CEST 2014 From: 7.7.11 To: 8.0.1 - Starting upgrade.
Thu Jul 31 13:47:37 CEST 2014 From: 7.7.11 To: 8.0.1 - Upgrade successful.
Thu Sep 11 10:49:18 CEST 2014 From: 8.0.1 To: 8.0.4 - Starting upgrade.
Thu Sep 11 10:57:24 CEST 2014 From: 8.0.1 To: 8.0.4 - Upgrade successful.
what to do with the pound status??
Contributor I
The problem is my SSL certificate, i found this link AMP SSL and followed the guide, but still im getting this error on pound:
/etc/pound.cfg line 14: SSL_CTX_use_certificate_chain_file failed - aborted
[FAILED]
