Network Management
No way to see traps from the controller to IMC
I tried to add an Aruba controller 7205 on the IMC, but I get strange traps (see screenshot "Issue_IMC")
There's also another thing, and I dont know if it is related, I configured the IMC as trap receiver on the controller, but on IMC, when I go to the controller and "trap destination" tab, I am not able to see any trap receiver ... (See screenshot "Issue_IMC2") and when I try to configure the trap manually on IMC, I got an error telling me there must be a SSH or SNMP issue...
Re: No way to see traps from the controller to IMC
Hi Alexis,
 Check AOS MIB guide for each trap detail  explanation.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/13020/Default.aspx
Regading HPE IMC issue, I would recommand to open TAC ticket with HPE IMC team.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
