I have a master controller which I want to point to two separate Airwave servers. The controller is currently only reporting to one Airwave server. I had to create a second AMP server to accommodate the number of devices the Master Controller/Local Controllers manage.
I believe all I have to do is add these two lines to the Master controller configuration.
mgmt-server type amp primary-server IP.ADDRESS profile default-amp
snmp-server host IP.ADDRESS version 2c COMMUNITY udp-port 162
Is that all? Will the Master controller send all traps/IDS events to both AMP servers? Will the AMP servers just disregard all traps that are not meant for it?
I have already configured each local controller to point to its particular AMP Server, it's just the Master Controller I'm curious about
