Network Management
PCI Compliance report whilst using Instant Config
Hi
We are using Instant config mode within our airwave v8.2.0.1  and all looks good.
However,  the PCI compliance report comes back with a fail due to Mismatches.  There are none.
If we switch off Instant config  The report passes successfully.
Are these 2 processes incompatible?
Many Thanks
Aruba
Re: PCI Compliance report whilst using Instant Config
I would suggest upgrading to 8.2.1.1 for the latest fixes regarding IGC.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
MVP
What version of code are you running on the iAP?
There is a lag between iAP code updates and Airwave updates - such that Airwave doesn't always parse iAP configurations as new features are added in iAP and aren't quite caught up in Airwave.
Possibly the two management modes aren't quite in sync either.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
I will try updating the airwave server and let you know how it goes.
The IAP firmware is 6.4.2.6-4.1.1.11 Does this need to be later also?
Many Thanks
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
This email has been scanned for viruses and malware, and may have been automatically archived by Mimecast Ltd, an innovator in Software as a Service (SaaS) for business. Providing a safer and more useful place for your human generated data. Specializing in; Security, archiving and compliance. To find out more visit the Mimecast website.
Upgraded to firmware 8.2.1.1  -  Still now joy.  It does the same
