Network Management
PSK based authentication: swarm is not approved in Airwave.
Hi Guys
We upgraded our Airwave to version 8.2.3.1 , And we deleted all our DB in order to start with fresh config.
We getting stange errors from our IAP's (that worked in the past)
Please advise.
How do i enable swarm in Airwave?
Re: PSK based authentication: swarm is not approved in Airwave.
Are you seeing this messages in Airwave events log? Could you try edit the VC key and check the status.
We see this issue , when we try to add an IAP to Airwave which is part of cluster previously, aiwave thinks it is old IAP which is already added to Airwave and it wont accept.Airwave recongnize each cluster based on GUID.
1) # show running | include virtual
2) copy the virtual-controller key
3) # conf t
4) # virtual-controller-key <paste copied kay>
5) change th last 2 digit of the key
sample key
virtual-controller-key 1bc58c2c014f78440e92d71fec0bc72428de77cef98b92624c
virtual-controller-key 1bc58c2c014f78440e92d71fec0bc72428de77cef98b92625d
6) # commit apply.
Pavan
If my post address your query, give kudos:)
Pavan
If my post address your queries, give kudos and accept as solution!
Doing it right now... will update soon,
But i have 200 diffrent VC'S with almost 1000 IAP's , I will need to do it one by one?!
Yes, if we are seeing same error for all IAPs. How did you reset the database?
We could reset the database by running below command
#amp_disable
#bootstrap_db
#amp_enable -now
#amp_version
copy the old backup file to /tmp and restore
#amp_restore -d /tmp/<backupfilename>
Note: Make sure, restore same version backup file. We cannot restore lowerversion backup file on higher version.
Regards
Pavan
Pavan
Thanks,BUT,I dont want to restore , i want to start from nothing.
*Even after running the bootstrap_db command , i still seeing the same errors on swarm is not approved in Airwave. *
Please advise. :(
Still same error:
If you still see the issue after bootstrap, try reset the VC key and check the status.
Pavan
Pavan
It's multiple VC'S (Something like above 300 different branches )
Is there any other way?
Have you tried resetting the VC key and checked ? Try restore the same version backup on server, if you have. If not, resetting the VC key is only option.
Make sure, you have valid Airwave license aswell.
Pavan
Pavan
Thanks,I will try again resetting one of the VC's key (via command line like you mentioned before,even due i tried on one unit,and it still in the event log...)
I'm now using the 90days trial license , should i install my official license? (the 90day license got limitations ? )
