Network Management
Occasional Contributor I
Pause / Kill Airwave Nightly Maintenance
Airwave v7.7.14.3
We are planning an early morning AOS upgrade at a time when Airwave nightly maintenance is normally still running.
Can someone please provide the CLI commands for cleanly pausing and killing nightly maintenance?
Re: Pause / Kill Airwave Nightly Maintenance
cli into Airwave and type crontab -e and comment out the crontab with #
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Moderator
this will work - but note that any access to the Amp Setup -> Network page of the Airwave will re-write the crontab entry back to it's original state.
regards
-jeff
