Network Management
Contributor II
PoE time-range problems in Airwave MAS Switch Config
[ Edited ]
Our setup:
Airwave 8.0.11.1
MAS Switches 2500/3500 running firmware 7.4.1.2_52793
Interface group IAP-TrunkPorts-Group
 The problem:
I am currently trying to setup a time-range for PoE on our IAP ports-group using airwave. When I set the following options we run into a weird 'mismatch' display before applying the switches:
TIME RANGE SETUP:
Time Range Mode: periodic
Start Day: Daily
Start time: 03:00
End Day: Daily
End time: 23:00
SWITCH AUDIT:
PoE End Day: 12/31/1969 4:00PM <<<
PoE End Time: 23:00
PoE Start day: Daily
PoE Start Time: 03:00
I get similar (wrong start date) information on the Audit when I do Specific start/end days as well. The Start Day entry shows up as <not set> when trying that config.
The question:
Obviously, an end date in the year 1969 is not going to produce the desired results. Is this a bug in airwave, or am I entering the settings incorrectly?
