Network Management
Pre-Auth Role
Hey Guys,
I am looking to add a pre-auth role to one of my SSID's like the below photo.  preauth.PNG
however i am running 8.2.6 and i cant seem to find this.  I used to be in the ssid -> access tab and put it to role based and it should be at the bottom, however it is not.
Any ideas where i would find this?
