Network Management
Frequent Contributor I
Problems opening the channel utilization to some users
Good morning everyone
I have a client who is with the following problem.
Depending on the client that logs on Airwave it opens or not the channel utilization.
All clients are authenticated via RADIUS and receive the same policies. Only the channel utilization chart does not work, the other open correctly.
Would anyone have any tips? I use the version 7.7.12
You can see the error on screen attached.
Thx All
Valued Contributor II
Re: Problems opening the channel utilization to some users
I wondering whether the AMON is working fine or not. open system-->Performance and go through those 4 graphs related to AMON. if you find many loss, please open a TAC ticket for further investigation.
Please feel free for any further help on this.
Cheers,
Venu Puduchery,
