Network Management
Contributor II
RAPIDS
Hi airheads.
I´m trying to override the AP classification on the controller using the Airwave´s RAPIDS Module.
My rules on the RAPIDs are working fine they are classifying very well, but  my controller is not changing the type of AP.
My controller still saying they are suspectect rogue.
How can I correct this?
The communication between the controller and the Airwave its ok (ssh and enable). I test it sending a command directly from the Airwave.
I´m Attaching a screeshot form my list of rogues in the controller and the RAPIDS setup.
Thanks in advance.
Re: RAPIDS
Have you setup Airwave on the controller as a management server? "mgmt-server type amp ...."
What version of AOS are you running?
What happens when you manually classify a rogue from Airwave?
Is it actually classified a rogue on the controller? "show wms ap list"
Visit this kb for more: https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Rogue-containment-from-Airwave-to-Aruba-controllers
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Contributor II
Re: RAPIDS
1.- Yes I have configured the Airwave as management server.
2.- AOS: 6.3.1.7 & Airwave: 7.7.10
3.- The change is only applied it the Airwave and change the classifying rule to "Manual classification override"
4.- No, they appears as interfeing.
5.- I saw the  KB and all its ok.
I´m attaching you 2 scrrenshoots related to the questions 3 & 4.
Re: RAPIDS
Can you show me your RAPIDS rule that you setup?
ACDX #420 | ACCA
Contributor II
Re: RAPIDS
Sure, Here you are. RAPIDS Classification Rule Rule name: Classification: Threat Level: Enabled: Yes No Device has been detected wirelessly: Yes No (remove condition) SSID: Matches Does Not Match Matches Regular Expression Enter a list of SSIDs, one per line. An asterisk (*) is a wildcard. Matching is case-insensitive, and ignores whitespace and non-alphanumeric characters. (remove condition)
Re: RAPIDS
EDIT:
You are classifying all SSID's as Rogues except for the ones in that list. Correct?
If all the proper settings are enabled as per the RAPIDS best practices guide and the kb article I sent you, the classification should be pushed down.I have followed similar practices and it works for me.
If that is not happening, a support case is the only way to get a deeper understanding of what is going on.
ACDX #420 | ACCA
Re: RAPIDS
erickyruiz,
The controller and Airwave maintain separate classifications for Rogues, etc.  To make changes in Airwave propagate to the controller, you need to enable WMS Offload:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Rogue-containment-from-Airwave-to-Aruba-controllers  You can configure WMS Offload here:  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-881
Re: RAPIDS
I thought WMS Offload is not needed for Airwave rogue containment, at least that is what TAC has advised me.
ACDX #420 | ACCA
Re: RAPIDS
pmonardo,
If you can find what they told you, that would be useful and we can discuss it.  To automatically have airwave sync its Rogue database with the controller we need to configure WMS offload.
EDIT:  I am wrong and pmonardo is right.
Here is how to configure Rogue Containment with Airwave without WMS Offload.  https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Rogue-containment-from-Airwave-to-Aruba-controllers
Re: RAPIDS
WMS offload for me was when the controller is under heavy stress to offload its WMS database to Airwave.
Thanks Colin but attempting to find that case that I opened 2 years ago would have been very difficult.
ACDX #420 | ACCA
