Network Management
Contributor I
RFPROTECT Feature and AIRWAVE MANAGEMENT
Hi All
If i only have PEFNG and AP licenses in my controller and use Airwave Management, what functionality do i loose in Airwave? I know Spectrum Analysis is one of them, is there anything else?
Mahathma
Re: RFPROTECT Feature and AIRWAVE MANAGEMENT
AirWave is not dependent on controller licenses.
Sent from Nine
Tim Cappalli | Aruba Security
Contributor I
Thanks Tim
Can i assume without RFProtect license in the controller i can get the following in Airwwave:
Event history, event correlation, spectrum visibility, location tracking and security reports etc.
Mahathma
