Network Management
Recommended Aruba Firmware for Aruba Mobility Controllers and IAPs
Where can we check the recommended IOS version for Different Models of Aruba Mobility Controllers and IAPs?
I need the recommened version and the latest version for Various Models.
Regards
Ranjan
Re: Recommended Aruba Firmware for Aruba Mobility Controllers and IAPs
On www.arubanetworks.com the controller and AP datasheets have the minimum version for each model.  There is no listing of recommended models.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks Colin for your reply.
But do we need to raise a Aruba TAC case for knowing the recommended version.
Regards
Ranjan
