Network Management
Remove Down Devices for Airwave 8.0.3
I have Airwave 8.0.3 and have been adding Alcatel Lucent OS6850. My remote site's seem to have caused an issue with the down device list not showing any rows. Is there a way to remove the devices via command line or a database editor. Attached is a screenshot of the list so you can see what I am. Here is a copy of the system event log too:
Re: Remove Down Devices for Airwave 8.0.3
There is a way. If you have not already, please contact support to ensure that you use the right command and if there is a bug, it can be reported and fixed.
Moderator
We suggest against direct database removal as it may leave some remnants in other tables.  It's best to do this operation from the GUI.  I suggest first upgrading to 8.0.4 (it's more stable).  Then go to an AP list view, select modify devices, bulk select the down devices and then delete.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
