Network Management
Report - Usager per devices
Hi, i would like to know if it is possible to create a report that show the bandwidth usage per devices/clients ?
Sometimes, i have "huge" download peak but i don't need which user use a lot of bandwidth or not.
Thanks !
Moderator
Re: Report - Usager per devices
[ Edited ]
You can try the Client Session report with the include details for every session flag.  One of the Pie Charts from that report may fulfill your requirement, depending on how granular you're trying to go.
Another option is Device Summary report -> there's a 'most utilized by usage' widget.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Nice ! Thanks !
It is pretty much what i looking for.
