Network Management
Report in Airwave with only Ethernet switch
I've tried to run/edit many times to show Network usage and Network total usage for only Ethernet Switch, but showed empty results. Currently running version 8.2.5 with Aruba 2530/40 series switch and report with Usage and Total Usage. Not sure which items of Custom in Report Definition of main Reports menu have to be selected or AirWave can't do this. Any ideas please share us.
Thanks.
Re: Report in Airwave with only Ethernet switch
Hi Alex,
If you are seeing usage data in monitor page of switch in Airwave then you could run device summary report which proivde the Total data/ average usage of each device.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Thanks.
At Available Option (in Report definition), It seems like I should not select Network Usage, but should select Port Usage or Device Summary instead when running a report for switch.
