Network Management
Reporting data by work hours
Hi all, i currently new on airwave, currently i using AirWave Management Platform 8.2.2.1, and i took some generated report, is there any way to soring it by work hour or weekday, example every 08:30 am to 5:30 pm every monday to friday, thank you
Re: Reporting data by work hours
Hi ,
We could run a report for specific time and also schedule the same report for daily, weekely and monthly in Reports>Definition page. Select any report type from drop down list and check below screen shot options.
Pavan
Pavan
If my post address your queries, give kudos and accept as solution!
Thank you for your reply :), btw can i doing sorting on home > apprf menu?
Airwave default retain 30 days of AppRF data, in AMP Setup> General >Historical page>
AppRF Data Retention Interval (1-30 days):
We could check the historical data on Home>AppRF page for 2hours, one day, one week, two weeks and also we could sort based on date.
We could also run AppRF report from Reports>Definition page.
Pavan
If my post addresses, your query give kudos:)
Pavan
