Network Management
Occasional Contributor I
Reporting on Planned Downtime?
Is there a way to run a report on, or get a list of devices that are in "Planned Downtime Mode?"
Moderator
Re: Reporting on Planned Downtime?
Currently there's not an easy way from the GUI.  This would be a great feature request though.
If you need a list, here's a db query that can help:
# dbc 'select a.id, a.name as device_name, a.planned_maintenance_mode, g.name as group_name, f.name as folder_name from ap a, ap_group g, ap_folder f where a.ap_group_id=g.id and a.ap_folder_id=f.id and state=1 order by g.name;'
It'll output to csv format, otherwise you can do:
# db
> /q
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
