Network Management
Running Airwave on a Laptop
Hi Gents
In a recent Airwave class we ran airwave on a Laptop.  I am looking at demo'ing airwave at a clients site for a few weeks (Free of Charge), and would like to do this as cheaply as possible.  Has anyone had experience of running airwave on a Laptop, and if so, what exactly were you using, and how was the experience.
Appreciate your time.
Regards
Robbie
Re: Running Airwave on a Laptop
This is from my experience:
Airwave can run on a laptop for only the smallest of networks (maybe 8 APs), due to the memory as well as the high disk IO requirements.
I want to use this for monitoring a Cisco core, and access layer switches to monitor the amount of Data flowing through it.  I suppose this is just not possible then?
There must be a fairly cheap way to achieve this?
Well, how many devices are we talking and what are the specs on your laptop?
Maybe 6 Switches - Core i5, 8gb Ram, 5400rpm drive.  Does it make a difference whether the switches are access layer or core switches?
If it is just 6 objects with a laptop with those specs, you should try it.  Make sure you give the VM as much memory as you can.
Does not make a big difference with the switches....
