Network Management
Occasional Contributor I
Re: SNMP get failed error after upgrade from Airwave 8.2.4 to 8.2.5
   hi, any update with this case? the same is happening to me, there is no problem with the 2530F, but with the 5406Zl2 it does not bring information
Firmware Software revision  : KB.16.04.0009
thank
Frequent Contributor II
Our local HPE Aruba SE was able to correct this problem by going into the configuration of the 5400-series switches and adding this:
snmp-server response-source dst-ip-of-request
Airwave then polled and the switches showed as 'up'. Why this configuration command is necessary now when it wasn't previously is unknown to me at this point, but it might be worth trying.
Contributor II
Thank you
The string "snmp-server response-source dst-ip-of-request" solved my problem.
Thank you, the problem was solved
This was a lot harder to find than I would have expected. Works perfect now. Thanks.
