Network Management
Frequent Contributor II
Selective AP monitoring
We have one 7210 controller 90 AP (15 different location), ClearPass & Airwave
I hv only 50 devices license. How can i add only selective 50 devices for monitoring in Airwave.
While i enter controller information into the airwave, it's pool all AP.
Thanks..
Re: Selective AP monitoring
You can "Ignore" some devices, if you want in Airwave.
After you adding your controller into the AW.All the new AP will be in "New Devices" - Drag (Choose) only the units you would like to monitor in the AW - the the right group/folder - AW will not count the devices under NEW DEVICES as devices that consume your license.
