Network Management
Setting correct timezone in airwave
I am sure I have missed in somewhere, but looks like our controller is on PST time, I need it on EST, where do I set that in the GUI?
I am currecntly running 7.7.9
Re: Setting correct timezone in airwave
Are you trying to set the time zone on the controller, from within AirWave, are you trying to set the time zone in the controller, or are you trying to set the time zone for AirWave?
Jerrod Howard
In the group configuration that your controller is in, you can set the timezone.
ACCP, ACCX #817, ACMP, ACMX #294
Colin Joseph
Aruba Customer Engineering
I am trying to set the timezone of the airwave server itself.  The controller has correct time, only the Airwave is incorrect.
You can only do this via the commandline:
Colin Joseph
Moderator
The best way to do this is from the command line.  Instead of re-running the entire install wizard, you can just run the portion that sets the time:
# cd /root/svn/mercury/install
# ./time-setup
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Perfect. solved my newb question in a matter of mins!
thanks
Also, it is important to make sure that the hardware clock is synchronized with the system clock:
[root@airwave mercury]# date
Wed Nov 4 09:16:57 EST 2015
[root@airwave mercury]# hwclock
Wed 04 Nov 2015 09:17:01 AM EST -0.851653 seconds
[root@airwave mercury]# hwclock --systohc
Contributor II
Hi Guys,
Just wondering if there is a way to set timezone in newer Airwave release with CLI access being vanished.
JayBee
ACDX | CCIE (RnS/SP,DC) | ACCP | ACMP | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
