Network Management
Occasional Contributor I
Some questions about Airwave generated reports.
I usually do a report every week and I generate my own custom Airwave report for this. One time, they ask me the meaning of some numbers and here are some I couldn't answer (attached). I hope someone can clear this up.
Thank you.
Re: Some questions about Airwave generated reports.
The reason you may not see the same numbers on the Unique Clients vs Total type of devices is because it will be based on the type of devices seen on each SSID .
Signal Quality is the SNR value
2014-11-07 22_26_43-How to_ Define Minimum SNR Values for Signal Coverage.png
Thank you
Victor Fabian
Lead Mobility Architect @WEI
